Upload suddenly been capped?
- Upload suddenly been capped?
14-08-2010 7:55 PM
Cheers
ADSL Link Downstream Upstream
Connection Speed 6338 kbps 444 kbps
Line Attenuation 46.5 db 23.7 db
Noise Margin 11.0 db 24.7 db
Mr Thicky here, has just noticed that ADSL2+ is now available on Value . I was one of the orig trialists, so I presume I was already on 21CN, and ADSL2+, but noticed in the announcement post, that initial Upstream would be 448. I wonder if my accounts been tweaked, or been in a blck move as I am value, and I have been dropped back to 448?? Does this sound like a resonable idea?
Re: Upload suddenly been capped?
14-08-2010 8:01 PM
14-08-2010 8:30 PM
See screenshot, of the router interface.
14-08-2010 9:38 PM
That is why I have Routerstatd running continuously as it differentiates between the two.
16-08-2010 11:02 AM
It looks like your interleaving has been removed and as a result the upstream has been capped at 448 - I suspect putting interleaving back on will remove that, but thought I'd offer the choice in case you'd rather keep the fastpath on there?
16-08-2010 11:38 AM
16-08-2010 11:49 AM
16-08-2010 8:21 PM
Interestingly, the member centre states Interleaving is ON......
17-08-2010 10:41 AM
17-08-2010 6:36 PM
Can you have interleaving put back on. had another resync event today, for no apparant reason, and sync now dropped to just over 6000. Line has always been stable with interleaving on. Can we also ensure the upload is not capped please. Why the hell did the DLM think this was a good idea. Anything you can do, to stop the DLM from p***ing about with my line please do, it fine with no intervention from the damn thing.
Cheers
18-08-2010 1:49 PM
I've asked one of the provisioning guys to place the order for you as it's not playing ball for me. I'll keep you posted but expect interleaving to be on for tomorrow if you don't hear anything
18-08-2010 2:57 PM
20-08-2010 8:20 PM
According to my router logs, the whole thing restarted for some reason 30mins ago. now not sure what happened before this, but my upload is back at 440, from 1024 yesterday. had the bloddy DLM been messing again.. Is is possible to override the DLM, and keep interleaving ON PERMENANTLY PLEASE. I dont game, and a slightly higher ping is of no consequence to me.
Also am I starting to have alot of disconnects again, the router I have, dosnt tell me when the resyncs were, just when the PPP connection is lost.
