Upload stuck at 64k!
- Upload stuck at 64k!
27-07-2016 11:45 AM - edited 27-07-2016 11:50 AM
I'm on a long line, but usually get about 700-800k upload. But it's recently syncing at 64k - help!
I've replaced the router (was using 2wire, and tried Plusnet router) but it's still the same. Any ideas?
Edit: that's a line sync of 64k
Re: Upload stuck at 64k!
27-07-2016 12:05 PM
I've tested your connection, however it's unfortunately not currently in sync.
Looking at the connection history for your line, it may be worth going through our troubleshooting guide. If that doesn't help, please raise a fault here.
27-07-2016 12:13 PM
Thanks Harry - it's down due to the 2704n not being able to sync.
I'll dig out a phone to test the line!
02-08-2016 11:49 AM
I'm still stuck at 64kb!
The phone line is quiet. A bit echo-y but no clicks, pops or whistles (from a quite line test).
There's normally no phone attached, and the router is straight into the master socket (via a filter). I think this is purely due to line length - I'm on 63db attenuation and 7db snr.
Is there something making the 64kb rate stick, or will this lift over time?
02-08-2016 11:54 AM - edited 02-08-2016 12:05 PM
02-08-2016 6:05 PM
Current rate: 64
Max rate: 176
Snr: 0
Attenuation: 31.5
03-08-2016 10:54 AM
This is going to need looking at as a fault, can you complete the faults checker here please https://faults.plus.net
03-08-2016 11:57 AM
Many thanks Chris - thought it might do!
Just raised it now.
