Upload sppeds on fibre extra.
- Upload sppeds on fibre extra.
30-10-2012 4:43 PM
Good afternoon,
I upgraded my fibre from value to extra a few weeks ago, have done a bt spped test (hard wired) :
Upload speed achieved during the test was - 9.21Mbps
Additional Information:
Does this result mean i should be getting more than 9.21Mbps? My download speed is at is not at its max either, still fast though ;D.(dont understand the second line though seems strange)
Download speedachieved during the test was - 45.59 Mbps
For your connection, the acceptable range of speeds is 12 Mbps-0 Mbps.
IP Profile for your line is - 55.54 Mbps
Thanks for any help
Thanks for any help
Message 1 of 8
(1,433 Views)
7 REPLIES 7
Re: Upload sppeds on fibre extra.
30-10-2012 7:53 PM
I managed to check this before I left the office, it looks like 9 MB/s is the maximum available on your line.
I will confirm this with you when I'm in the office in the morning.
Message 2 of 8
(629 Views)
30-10-2012 8:23 PM
Thanks, if that's the case no problem, do you know when speed will be increased in my area? I was just going on the B.T. speedtest.
Message 3 of 8
(629 Views)
30-10-2012 8:33 PM
It just means that there is no restriction on your upload, it depends on your distance from the cabinet as well as other things like the quality of copper.
Message 4 of 8
(629 Views)
30-10-2012 10:57 PM
Quote from: jimbo99 Upstream Rate IP profile on your line is - 20 Mbps
Surely something is wrong here! The upstream profile reported by the BT speed test normally says something sensible I thought.
Message 5 of 8
(629 Views)
31-10-2012 7:52 AM
No, nothing wrong with the 20Mbps upstream profile, that's the maximum set for the line and, on FTTC, will match the product specification (2, 10 or 20Mbps), all it means is that the line is limited to this speed on upload (if it can't achieve that speed due to distance from cabinet or other reasons then it simply doesn't hit the restriction).
Call me 'w23'
Message 6 of 8
(629 Views)
31-10-2012 9:07 AM
I've checked your line upload and your're actually getting higher than your estimated speed. The 20MB/s profile rate on your upload is referring to the product you're on.
Message 7 of 8
(629 Views)
31-10-2012 10:48 AM
Ok thanks Chris for your quick response.
Message 8 of 8
(629 Views)
