Upload speeds
mcyates
Upload speeds
I've notice its taking ages for me to upload photos and videos, but it never used to when I was with Sky.
I have been with Plusnet for just over 2 weeks. My upload speed with sky where pretty good, about a MB, but plusnet is much much slower.
Whats the maximum upload speed with Plusnet?
Thanks in advance.
My Football Forum - http://www.myfootballforum.com
Fixes: 4
Re: Upload speeds
As you have posted this question in the ADSL board, I'll assume you have ADSL and not fibre.
Your upload speed will depend on which ADSL type your router is using to connect to the exchange, the quality of your connection, whether your upload profile is capped or not, and whether you have paid extra for a premium upload speed.
Can you post here your modem/router's ADSL statistics ?
mcyates
Re: Upload speeds
Thank you for your reply, yes its ADSL
Your Plusnet adviser may ask you for the following information:
1 - Product name: Plusnet Router
3 - Firmware version: 7.275.2_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 7 days 08:53:23
7 - Data rate: 1171/19623
8 - Maximum data rate: 1184/19992
9 - Noise margin: 6.1/3.4
10 - Line attenuation: 10.0/21.0
12 - Data sent/received: 1.1G/476.1M
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: Automatic (Smart Wireless)
25 - Firewall: Default
27 - Software variant Version 1.0
28 - Boot loader: 7.275.2
Phone exchange:
MIDDLESBROUGH
Estimated line speed:
17Mb (This may vary between 15.5Mb and 19Mb) - Checked on 2016-03-25 21:42:08
Current line speed:
17.3 Mb
cedlor
Re: Upload speeds
You need to delete line  2,  line 20,  line 21, line 26  from your post asap Wink
Fixes: 4
Re: Upload speeds
So you are on "ADSL2+", with a good quality connection, the upstream appears to be uncapped, and no premium service.
With that upload data rate, then your upload speed test results should be about 1Mbps, which is about as good as it gets.
Gel
Seasoned Pro
Fixes: 14
Re: Upload speeds
mcyates
Re: Upload speeds
Quote from: cedlor
Thanks, I deleted them, didn't realise!!
mcyates
Re: Upload speeds
Quote from: Nibiru
I'll do a speed test once i've stopped watching the Liverpool Spurs game on NowTV.
mcyates
Re: Upload speeds
http://www.speedtest.net/my-result/5219503774
16.51 Download
0.99 upload so no problems.
Seems the same as sky.
