Upload speeds
sallonoroff
Upload speeds
Following my recent change of home networking kit, our ADSL download speed is consistently around 12mbps (I think the fastest it has ever been) but the upload is only 700-800kbps.
I have asked PN to disable their upload limitation before now, so is 800kbps likely to be all my line is capable of? Or does that upload speed cap thingy get reset periodically? I'm convinced that once upon a time I would see 1mbps uploads.
10 REPLIES 10
Chris
Legend
Fixes: 169
Re: Upload speeds
Your upload is definitely uncapped, if it was capped you'd only be connecting at 448k rather than the 864 you're currently seeing. It is possible that your line will connect a little higher but any changes will be minimal really.
sallonoroff
Re: Upload speeds
Oh well, guess I'll have to wait for fibre. And tether my phone when I want to upload something quickly in the meantime. Smiley Thanks for checking, Chris.
Fixes: 160
Re: Upload speeds
sallonoroff,
Can you pleas post your full router stats here.
@Chris,
Is there any US SNRM "headroom" on this line?  I take it that US and DS SNRM targets are / can be specified independently of each other?
Kevin
sallonoroff
Re: Upload speeds
Quote from: Townman
I'm not sure I can. I've got a Netgear DG834GT running in modem-only mode, so (afaik) there's no way to get at the web interface anymore. Well, not without paper-clipping it back to factory settings, getting the stats, then reconfiguring as modem-only again.
...or might a crossover cable help get me into it?
Chris
Legend
Fixes: 169
Re: Upload speeds
From memory there was a little headroom, but not much which is why I didn't think there would be much wiggle room. We can specify the up and down SNR separately on a reset, I'll give it a go now but we can't place another reset for 10 days.
It's gone through, I'm just trying a line test whilst crossing my fingers that it's helped/
Chris
Legend
Fixes: 169
Re: Upload speeds
It's still showing exactly the same upstream speed at the moment. It may just take a little more time to go through if it's going to help at all.
sallonoroff
Re: Upload speeds
Thanks for that Chris. Upload speed doesn't appear to have changed at all though. Download has improved a bit more though... seeing 13+mbps occasionally now.
MatthewWheeler
Fixes: 479
Re: Upload speeds
Your line currently has interleaving turned on which might be restricting your upload speed .
I've placed a order to turn it off which will complete tomorrow and should hopefully give you better performance.
If your still having any further issues let us know.
 Matthew Wheeler
sallonoroff
Re: Upload speeds
Thanks Matthew! Had to reboot my Airport this morning (it had lost the PPPoE connection during the night) but we now have 1mbps upload speeds. Grin Ping times also seem a little improved and a couple of download tests momentarily hit 14mbps.
MatthewWheeler
Fixes: 479
Re: Upload speeds
Fantastic  Cheesy
Glad to see that's done the trick.
If you have any further issues please let us know.
 Matthew Wheeler
