Upload speeds dropped
- Upload speeds dropped
20-03-2013 8:18 AM
It seems my upload speeds have dropped about 5Mbps since last night.
Normally I get just short of 12Mbps. This morning it's just over 7Mbps.
Anyone else getting this problem?
Cheers
Nathan.
Re: Upload speeds dropped
20-03-2013 8:57 AM
Do you get the same results on the BTW speed tester?
20-03-2013 3:31 PM
I'm on FTTC too. I should of added that. I just did the BT speed test with the following results.
Download: 50.98Mbps
Upload: 6.93Mbps
Further tests showed : Upload speed achieved during the test was - 6.93Mbps
Additional Information:
I miss my 12Mbps upload
Nathan
20-03-2013 3:59 PM
Upload speeds as with downloads can vary but given the amount that's decreased by I'd best advise you to raise a fault:
http://faults.plus.net
20-03-2013 4:01 PM
As Adam says, it does sound like a fault...
20-03-2013 6:05 PM
I say this because I loose speed up & down periodically and that's how I get back to normal!
York.
20-03-2013 6:15 PM
Thanks for the advice. I have started the fault report process and I shall start the three BT tests tomorrow.
Nathan.
20-03-2013 6:17 PM
Nathan.
20-03-2013 7:34 PM
I have to say that since joining PN my connection has been rock solid. The odd times the speed has nose-dived (to less than 5meg!) a reconnect or reboot cures it!
York.
21-03-2013 4:09 PM
Thanks for the help
Nathan.
