Upload speed
Woody3600
Upload speed
Hey guys, my current upload speed is around the 0.7 - 0.9 mark, is there anyway i can increase it at all? I have a YT channel and uploading regularly is becoming increasingly frustrating due to huge upload times x
Fixes: 10
Re: Upload speed
Those sort of speeds are about as good as it gets on ADSL, you might squeeze a bit more but you wouldn't see a dramatic increase.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Woody3600
Re: Upload speed
I think we're on ADSL2+ but i'm not sure? Is that a thing? lol Is it fibre optic or still not ver good quality? D/L is 20mb max atm x
Fixes: 10
Re: Upload speed
You can check if anything faster is available by putting your phone number in to here: http://www.dslchecker.bt.com/adsl/adslchecker.welcome
(Note Annex M is only available to business users)
Woody3600
Re: Upload speed
It's correct when it says i have ADSL2+ with downloads of up to 20, but it doesn;t say anything about upload other than that "Annex-M" which is around 1.5mb/s. Why if it can support that for business users can it not support it for me as a normal user? x
Fixes: 10
Re: Upload speed
You do realise that Annex M costs an extra £10 per month(excluding VAT I think) and also reduces your download speed?
Estragon
Re: Upload speed
I think it might not reduce the download speed, or at least not significantly, with the speed he has. Particularly if his 20Mbps is throughput not sync.
Re: Upload speed
Not so. Using Annex M to increase the upload takes away bandwidth from the downstream frequencies. See here.
Fixes: 10
Re: Upload speed
Annex M always reduces the download speed - it reallocates frequencies usually used for download to the upload. I think you are getting confused with uncapping the download to give the speeds above 448k up to around 1.3M which sometimes reduces it a small amount.
Edit: Jaggies beat me to it!
Estragon
Re: Upload speed
No to both of you  Smiley.
I agree that Annex M grabs a chunk of the upstream Annex A allocation.  On very short lines where over 20Mbps downstream sync is easily obtained there is sufficient spare space in the downstream bins to compensate for the lost low-end bins.
This has been consistently shown on Be LLU.  I'm not aware of there ever being an exception. The rule of thumb on Be is that with 16Mbps or lower Annex A, forget Annex M as you lose 2.5Mbsp downstream with a tiny upstream gain, and at 20Mbps+ you get approaching 2.5Mbps upstream with no loss of downstream  Tongue.
However, I will grant you something that perhaps I am not aware of.  It is possible that whoever specified the WBC DLM screwed up and didn't allow that bit-shifting to happen. So maybe we are all both right and wrong.
Fixes: 67
Re: Upload speed
I believe Plusnet not offering Annex M to residential users is simply a commercial decision.
David
