Upload speed
garethv4
Upload speed
Hello,
I'm experiencing very low upload speeds - all the online tests I've done have come back under 1 mbps.  My upload speed is good around 9 to 10 mbps.  Are there any settings I can change or ways to improve my upload speed?Huh
Thanks in advance,
Gareth
Gel
Seasoned Pro
Fixes: 13
Re: Upload speed
garethv4
Re: Upload speed
Yes sorry my download speed is fine.  Just my upload speed seems very slow whenever I do a speed test
All Star
Fixes: 6
Re: Upload speed
On ADSL, you will never achieve an upload speed greater than around 0.7/0.8Mbps - not on Plusnet, anyway.
Gel
Seasoned Pro
Fixes: 13
Re: Upload speed
Twills
Re: Upload speed
Hey Garethv4. I am seeing a high amount of uploading. This will be causing your remaining throughput to be pretty low. Check your devices for uploading, turn it off (if you want) then check your speed Smiley
An 0.8Mb upload sync speed max per hour is about 375MB to put it into context.
Twills
