Upload speed
lizzie1965
Upload speed
Done a speed test yesterday and it shows an upload speed of just  0.38mbs this seems very slow? Tried to upload photo to photobucket and after 5 mins still not uploaded.What speed for uploading should i be achieving? Download is normally around the 14mbs mark.
Thanks.
Fixes: 162
Re: Upload speed
It's possible that your upload is still capped at 448k, let me go take a look and I'll post back shortly.
 Chris Parr
 Plusnet Staff
lizzie1965
Re: Upload speed
OK thanks.
Fixes: 162
Re: Upload speed
That should be sorted tomorrow for you, I've placed the order to uncap your upload. It should give you around double what you're seeing at the moment, maybe a little more.
 Chris Parr
 Plusnet Staff
vaughnrice
Re: Upload speed
Plusnet are owned by BT and provide the worst service I have ever know. They have multiple broadband issues and consistently pass the buck to the customer instead of using skilled engineers to repair there faults.
I have sent in access of 40 messages and had no response to most of them  accept to close the issue as resolved. Now over 1 year and still my broadband worse than tethering of my mobile . LEAVE AS FAST AS YOU CAN.
vaughnrice
Re: Upload speed
Mmm You admit capping
Moderator's note by Dick (Strat) All caps removed as per Forum rules
lizzie1965
Re: Upload speed
upload has nearly doubled but 1 hr 30 mins to upload 505mb vid is ridiculous, going to look at other ISP s now.
Fixes: 162
Re: Upload speed
I'm afraid that on an ADSL connection it's very unlikely to get anything faster upload wise with any other ISP, it's the nature of the technology. You can see the estimates for the upload are up to 1Mbs.
If upload is important to you it might be worth looking at a fibre product as the uploads on those are much better, in particular the Fibre Extra service.
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 69.8 20 20 -- Available -- --
VDSL Range B (Impacted) 73.9 40 20 11.2 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 12 -- 11.5 to 13 Available -- --
WBC ADSL 2+ Annex M Up to 12 Up to 1 11.5 to 13 Available -- --
 Chris Parr
 Plusnet Staff
Fixes: 162
Re: Upload speed
ADSL can be ordered with a 448 upload, or uncapped. Sometimes the order gets placed incorrectly as 448 as this is what it defaults to in our suppliers systems.
 Chris Parr
 Plusnet Staff
