Upload speed
geehawk
Upload speed
Hi
I have noticed recently that my upload speed seems to be very slow lately.
It has never been particularly fast IIRC but I don't consciously use it much, however lately I have been getting messages when gaming online (PS4) about slow broadband and whilst the download is it's usual 12ish mb, upload is hovering somewhere below 1mb.
Is this correct ? Is there any way of upping my upload speed?
I have never had these messages before so assume it must have been consistently over 1mb in the past.
Cheers
Graham
VileReynard
Seasoned Pro
Fixes: 10
Re: Upload speed
Try running https://sourceforge.net/speedtest/
It should give some useful stats.
Fixes: 162
Re: Upload speed
Upload of around 1Mb/s is what I'd expect to see on an ADSL2+ line, generally you wouldn't see anything over 1.2Mb/s. I'm afraid that if you did need a higher upload speed you'd probably need to look at fibre if it's available to you.
 Chris Parr
 Plusnet Staff
