Upload speed
mikesin
Upload speed
Can I get an increase in my upload speed ?
Modem shows this
ADSL Link Downstream Upstream
Connection Speed 2887 kbps 445 kbps
Line Attenuation 56 db 17 db
Noise Margin 7 db 15 db
speed test results
Today 09:26 2132 kbps (267kB/s) 375 kbps (46.9kB/s)
Thanks Mike
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Upload speed
Hi mikesin,
I've just placed an order for your upload speeds to be uncapped. You should notice a change in the early hours tomorrow morning.
Chris Pettitt
Cloud Environments Engineer
mikesin
Re: Upload speed
Many thanks will try later
mikesin
Re: Upload speed
Tried sped test today
Today 05:58 2159 kbps (270kB/s) 331 kbps (41.4kB/s) Share
Today 05:46 2281 kbps (285kB/s) 350 kbps (43.8kB/s) Share
Connection Speed 2963 kbps 656 kbps
Noise Margin 9 db 6 db
Connection upload speed gone up but throughput gone down ?
Fixes: 16
Re: Upload speed
Based on your previous posts, your netgear DG834GSP v3 may benefit from newer firmware, based on the firmware version of V1.01.03 it might take the same firmware as the standard DG834G v1 and v2.
Also it may benefit from being set to ADSL2 rather than auto which will end up connecting as ADSL2+. It may also benefit from various other tweaks or even a new power supply, but setting ADSL2 mode and all other tweaks have to be done via telnet. Anyway, any problem will initially be blamed on the netgear once Plusnet realise what it is.
mikesin
Re: Upload speed
Thanks - will try ADSL  - tried no effect
Rather than mess with firmware of modem I will try putting plusnet original Speedtouch modem back into play.
2100 Tried speedtouch and got 600K upload - replaced netgear and guess what ....got 600k upload. Obviously the un-capping took time to come into effect -glad i ddin't mess with Netgear firmware. Removed change to ADSL setting as it had no effect on upload speed
Thanks plusnet
