Upload speed low recently
benmango
Hi, we've recently noticed a real dip in our upload speeds - we had 0.2 tonight & 0.1 the past few evenings about the same time. Wondering if it's being capped in some way.
Can someone from Plusnet please look into this?
Ben
Kremmen
Re: Upload speed low recently
Isn't this strange that I've noticed a few of these posts recently !
Mine did exactly the same a week ago and a cap was noticed.
Let's be careful out there !
Fixes: 4
Presumably you are talking about speedtest resuls ?.
Are you sure that another device in your house isn't using the upstream for p2p, or watching video, etc ?
Have you checked whether the upstream sync speed as reported by your router has reduced ?
Have you tried the "BT Wholesale Broadband Performance Test" to see what your exchange thinks your line can achieve ?
Enter your phone number in the box to the right of "Telephone Number of the broadband circuit:".
Click on the "Run Diagnostic Test" button.
Click "OK" to confirm that your phone number is correct.
Wait for the "Test Results" page to appear.
Kremmen
In my case I used both Speedtest on my phone and via PC CAT to check. I was seeing speeds ranging from 0.02 to 0.1 depending on the time of day.
Since PN intervened I'm now up to 0.6 on average which has done the trick.
