Upload speed has dropped to < 60Kbps
- Upload speed has dropped to < 60Kbps
03-04-2013 10:42 AM
Noticed my upload speed has dropped from around 300kbps to less than 60kbps.
The router is reporting downstream rate of 2944kbps, upstream rate of 64kbps.
speedtest.btwholesale.com reports:
Upload: 0.00
Ping: 81.13
Thoughts?
Re: Upload speed has dropped to < 60Kbps
03-04-2013 11:42 AM
We should be able to reset that once the connection is stable again but we'll need to concentrate on that first so I'd advise raising a fault about that: http://faults.plus.net
Adam
04-04-2013 4:43 PM
I haven't noticed any drop outs but I did disconnect router a few times when we had an issue with xbox live connectivity.
I will disconnect any none essentials (upstairs phones etc) and leave it a couple of days.
Will
a) the upstream speed auto increase again if the disconnects stop?
b) will you be able to tell me if the connectivity is stable in a few days time (given I haven't noticed any issues myself)?
Ive found the "Linksys hidden page" status which is showing the following. Are these as expected?
DSL Upstream Rate: 64 Kbps
DSL Downstream Rate: 2944 Kbps
Down up
DSL Noise Margin: 9.9 dB 7.0 dB
DSL Attenuation: 58.0 dB 31.5 dB
DSL Transmit Power: 18.7 dBm 10.9 dBm
Back in Dec I was getting:
DSL Upstream Rate: 352 Kbps
DSL Downstream Rate: 3168 Kbps
Down up
DSL Noise Margin: 6.3 dB 6.0 dB
DSL Transmit Power: 18.1 dBm 12.5 dBm
04-04-2013 4:56 PM
Your upload speeds may improve if there is a stable connection. We'll be able to check your recent connectivity in a few days.
Chris
06-04-2013 10:22 AM
09-04-2013 11:00 AM
Looks like it is still dropping at the moment, did the engineer attend yesterday at all?
14-07-2013 6:27 PM
my upstream rate has dropped again - down to 224. My downstream has also dropped.
Shame as May/june it has been great since the bt engineer replaced wiring outside our house.
Are you seeing disconnects your end. Not noticed anything my end. Probably doesnt like the hot weather 🙂
DSL Upstream Rate: 224 Kbps
DSL Downstream Rate: 3232 Kbps
Down up
DSL Noise Margin: 6.0 dB 6.0 dB
DSL Attenuation: 59.0 dB 31.5 dB
DSL Transmit Power: 18.4 dBm 12.1 dBm
14-07-2013 8:11 PM
I've just had a check before I go home and we haven't seen a disconnect for over 3 days.
Those figures seem to be better than the ones you posted previously? Although they are not quite back up to what you were on in December, they do seem to be increasing.
17-07-2013 9:04 AM
The speeds are better than April ... but worse than they have been inbetween. Can't recall exacts but my upstream was 370 ish and downstream was high enough to allow 3mbit... currently 2.5mbit.
I blame the weather
Is there a way to get visibility of disconnects (as you see it your end) without needing to ask?
17-07-2013 7:15 PM
18-07-2013 9:53 AM
Quote from: ericnel Is there a way to get visibility of disconnects (as you see it your end) without needing to ask?
There's not, but give us a nudge if you require one.
<img src="http://community.plus.net/visualradius/generated/image13741375765886.png"/>
