Upload speed halved
- Upload speed halved
Upload speed halved
12-11-2009 4:44 AM
PlusNet Broadband Premier ( Legacy / BT IPstream Max Premium Upto 832kb\s Upload)
2. Your current usage from the VMBU
Peak usage: 6.1GB
Off-peak usage: 239.76GB
Total usage: 245.85GB
3. Your IP Profile, as reported by Plusnet
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed: 7150
4. Information from the BT Speedtester
Download speedachieved during the test was - 4311 Kbps
For your connection, the acceptable range of speedsis 600-7150 Kbps.
Additional Information:
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 6500 Kbps
5. A Speedtest from an external testing site.
6. Your gateway
You are currently connected to the "City Lifeline, Juniper 11" gateway. This gateway is sometimes known as pcl-ag04.
7. Your exchange status
Exchange: Vauxhall
VP capacity at this exchange is currently showing as Green.
8. Any other information
Download speed has dropped only slightly thou stil noticeable. Upload Speed is the problem where Router is syncing at 448kbps, of which it normally syncs at 832kbps, and therefore upload speed has been reduced,
This changed after restarting Router after loss in connection and has not changed after several reboots.
Details as of this connection are Downstream & Upstream Respectively
SNR Margin (dB) : 14.0 27.0
Attenuation (dB) : 25.0 13.0
Re: Upload speed halved
12-11-2009 9:12 AM
Seems that this issue is to do with upload speed not synching at the Max Premium so I have split it out.
12-11-2009 10:36 AM
I haven't resynced recently - not sure I want to!
Re:Upload speed halved
13-11-2009 1:47 PM
13-11-2009 3:58 PM
16-11-2009 9:30 AM
07-12-2009 4:47 PM
Internet was offline when I arrived back therefore restarted router and it seems Download Speed has now dropped.
Upload has reached beyond what it was before (Syncing at 928Kbps which is higher then the usal 832 I had), But download speed has been reduced from what i had before by about 1.5Mbps
Restarted router many times but acheiving same results.
07-12-2009 4:50 PM
What are your router stats?
07-12-2009 5:04 PM
My Router Stats are
Downstream Upstream
Rate (Kbps) : 7616 928
SNR Margin (dB) : 13.1 12.0
08-12-2009 7:44 PM
therefore having to constantly reboot the router (regardless of which one I use) to get a connection active again.
08-12-2009 10:25 PM
11-12-2009 4:08 PM
But Still, my download Speed hasnt changed. Its still reduced, and upload is remaining at 928 Upstream (which I dont mind lol) but download nothing has been done about that.
14-12-2009 8:57 PM
14-12-2009 9:49 PM
14-12-2009 10:37 PM
