Upload speed from 0.4 to 0.6Mb/s after cap being removed???
- Re: Upload speed from 0.4 to 0.6Mb/s after cap bei...
19-12-2013 11:10 PM
Can some advice please?
Re: Upload speed from 0.4 to 0.6Mb/s after cap being removed???
20-12-2013 9:41 AM
20-12-2013 9:50 AM
Quote from: rpucyk I have been told I could go for full 1.3 Mb/s upload speed but at the cost of download speed (???).
In about 5 years time we may manage to educate the CSC staff and stop them spouting such rubbish!
20-12-2013 10:03 AM
Quote from: Oldjim please post the stats from your router http://community.plus.net/forum/index.php/topic,96155.0.html
Thanks for reply Oldjim, will post as soon as I will finish work
20-12-2013 10:06 AM
Quote from: jelv
Thanks for reply Jelv, I take it I suppose to get the max speeds available both down and upload without cutting any of them?
20-12-2013 10:48 AM
20-12-2013 1:25 PM
DSL Connection
Link Information
Uptime: 0 days, 14:39:20
DSL Type: ITU-T G.992.1
Bandwidth (Up/Down) [kbps/kbps]: 768 / 5,728
Data Transferred (Sent/Received) [MB/MB]: 14.40 / 143.56
20-12-2013 1:29 PM
20-12-2013 4:53 PM
20-12-2013 6:37 PM
Your upstream noise margin seems to have been set at 12dB by the automatic system
I have no idea why and it will probably need line reset to fix it which can only be done by the Plusnet staff
20-12-2013 6:41 PM
Quote from: rpucyk DSL Type: ITU-T G.992.1
That indicates you are on ADSL1, although ADSL2 might be better.
Quote Line Attenuation (Up/Down) [dB]: 30.0 / 48.0
Upstream line attenuation does seem to be a bit high compared with the downstream attenuation, usually the upstream attenuation is about half, or slightly more than half of the down attenuation.
20-12-2013 7:28 PM
I'm just looking into this now.
The line is uncapped and the noise margin target for your upstream is set to 6db so something does seem to be dragging that up a bit.
Is the router going into the Master socket or ideally the test socket?
20-12-2013 9:12 PM
20-12-2013 9:30 PM
20-12-2013 9:32 PM
Quote from: rpucyk not really sure what test socket means
