Upload speed down after line drop
The wordy subject says it all. I had a line drop and my upload went from 832 KBit/s to 512KBit/s.
Since I'm on 20CN and have to pay for the extra upload bandwidth can I get some sort of SNR reset to see if we can bump it back to 832 KBit/s?
Cheers,
A.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
Fixes: 166
Re: Upload speed down after line drop
That'll be submitted shortly. If it doesn't work then it's probably time to look at it as a fault.
 Chris Parr
 Plusnet Staff
Followed the faults checker, once in the test socket.
A little detective work and the TV aerial extension I'd recently reactivated to get from the roof to the kitchen was a big enough loop (when combined with the big loop that is the 5 extension sockets on the phone line) to be causing interference to knock the speed down.
The line drop and re-sync was the first time a resync had been triggered since then.
All sorted now and DLM doesn't seem to have gone Woah that line is unstable and put interleaving on.
Cheers,
A.
