Upload from outwith Plus Net network?
donka
I am going to be away from home but still have a requirement to upload files to my Plus Net webspace. I can connect and read using FTP on a different broadband connection but I cannot upload. Is this doable or is it just not an option? I may need to find another provider if this is not an option.
12 REPLIES 12
geewizz
Re: Upload from outwith Plus Net network?
what ftp client are you using?
Chris
Legend
Fixes: 169
As long as you are on a paid account you should be able to use the ftp.plus.net address and upload to your webspace from any location. Unfortunately you can't upload to ccgi.plus.net from outside the Plusnet network.
Can you telnet to ccgi from outside the PN network?
Chris
Legend
Fixes: 169
TBH, I'm not sure. It's possible that you can telnet to it from outside the network but I'm pretty sure it won't authenticate you.
Was just wondering if you could ftp stuff to homepages, then use something like wget to grab a copy onto your ccgi box.
Just thinking laterally - I suspect its not an option though.
zubel
No route to host from outside the PN network for me.
[root@esrb01 ~]# traceroute ccgi.plus.net
traceroute to ccgi.plus.net (84.92.1.4), 30 hops max, 38 byte packets
1  hosted-by.trans-ix.com (83.98.136.1)  0.670 ms  1.881 ms  0.934 ms
2  cr03.trans-ix.nl (83.98.137.233)  0.909 ms  1.924 ms  1.944 ms
3  89.30.132.9 (89.30.132.9)  3.923 ms  3.937 ms  11.981 ms
4  89.30.133.2 (89.30.133.2)  2.983 ms  4.974 ms  2.987 ms
5  89.238.128.69 (89.238.128.69)  4.993 ms  4.973 ms  5.990 ms
6  tc2-thn.10g.nl.as33970.net (89.238.140.25)  9.991 ms  11.967 ms  10.976 ms
7  no-rdns-yet.ohtele.com (89.238.140.21)  123.942 ms  190.881 ms  206.855 ms
8  linx-gw1.plus.net (195.66.224.164)  9.963 ms  8.957 ms  10.988 ms
9  vl23.thn-gw2.plus.net (212.159.4.20)  9.990 ms  10.973 ms  8.981 ms
10  vl23.thn-gw2.plus.net (212.159.4.20)  8.980 ms !X * *
11  * * vl23.thn-gw2.plus.net (212.159.4.20)  11.240 ms !X
12  * vl23.thn-gw2.plus.net (212.159.4.20)  91.105 ms !X
[root@esrb01 ~]# ping ccgi.plus.net
PING ccgi.plus.net (84.92.1.4) 56(84) bytes of data.
64 bytes from ccgi.plus.net (84.92.1.4): icmp_seq=0 ttl=56 time=9.69 ms
64 bytes from ccgi.plus.net (84.92.1.4): icmp_seq=1 ttl=56 time=9.19 ms
64 bytes from ccgi.plus.net (84.92.1.4): icmp_seq=2 ttl=56 time=9.57 ms
--- ccgi.plus.net ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2024ms
rtt min/avg/max/mdev = 9.194/9.490/9.697/0.214 ms, pipe 2
[root@esrb01 ~]# ssh ccgi.plus.net
ssh: No route to host.
[root@esrb01 ~]#
B.
donka
Quote from: geewizz
ftp from command prompt, FileZilla and CuteFTP. All the same.
donka
Quote from: Chris
I'm paying £15 a month for Plus net. Does this constitute a paid account? I can connect using ftp.plus.net and browse the directories but it appears to be read only. I cannot upload any images for example.
Chris
Legend
Fixes: 169
Are you having any issues from your PN connection when trying the same?
Are you uploading files inside the htdocs folder?
I could try uploading a small file from here to test if you would like?
donka
No issues when I try in on the PN network from home - it works fine. I am trying to upload to a sub folder inside htdocs.
The error message I get just now from work is '550 Security server forbids that action on this file' using ftp from the cmd prompt. I can log in and browse but I get this as soon as I try to send a sample .jpg file. Is this something on my corporate network on PN network?
Peter_Vaughan
When away, are you on a company network using Windows Small Business Server 2003 with ISA Server 2004 firewall?
If so, by default it sets FTP connections as read-only so you can see files but not upload/change any. You would need to contact the admin of the server to configure ISA to allow uploading.
Any connection to the ccgi server (telnet/ssh/ftp) is only allowed from a PN IP.
Could you perhaps remote into your PC at home and upload from there?
donka
Quote from: Peter
That sounds like the issue then. If it is a work server issue then I will try and find another connection when I am away or remote onto my home pc and work that way. Thanks for the info, at least I know it isn't a PN issue then. Smiley
