Upload capped again?/ Something screwy
- Upload capped again?/ Something screwy
31-03-2009 7:58 PM
Link Information
Uptime: 0 days, 0:00:10
Modulation: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 456 / 7.144
Data Transferred (Sent/Received) [KB/KB]: 1,00 / 0,00
Output Power (Up/Down) [dBm]: 12,5 / 0,0
Line Attenuation (Up/Down) [dB]: 24,0 / 41,5
SN Margin (Up/Down) [dB]: 9,5 / 6,5
Can anyone explain??? Stats from last night
Now
Profile on PN side is 5500, so must have had a sync blip for some reason, but upload speed concerns me, after 1 blip, do BT now deem my line as unstable and cap my upload?? be very peeved if they have!!!
Re: Upload capped again?/ Something screwy
31-03-2009 11:11 PM
I think PlusNet and BT need to take a closer look - just look at the number of comments on here?
01-04-2009 9:25 PM
03-04-2009 7:07 PM
Link Information
Uptime: 0 days, 0:07:03
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 595 / 7.051
Data Transferred (Sent/Received) [kB/kB]: 156,00 / 642,00
Line Attenuation (Up/Down) [dB]: 24,0 / 44,5
SN Margin (Up/Down) [dB]: 13,0 / 7,0
Would welcome any advice... Strangely Down Attn has gone from 42 on ADSL MAX, to 41.5 on ADSL2+, and now after firmware update to 44.5.....
03-04-2009 7:50 PM
03-04-2009 8:14 PM
03-04-2009 11:56 PM
Your downstream sync speed is about right for the attenuation but upstream sync speed is undoubtedly poor. It isn't clear whether the elevated upstream (target?) noise margin is the cause of this, or results from the poor upstream sync speed. You are not alone in experiencing this behaviour and it is something the Plusnet need to look into, but I've seen nothing that suggests they are doing so.
If you do reset the router, and that cures the CRC/FEC anomalies, it is possible the DLM will sort out the upstream noise margin. If it persists I suggest you raise a fault ticket marked for the attention of the 21CN trials team.
Generally one expects "weighted-average" attenuation to increase slightly with ADSL2+ because higher frequencies are brought into play, and attenuation is higher at these higher frequencies.
David
04-04-2009 10:35 AM
Sync is still unstable, so I am going to move the router and plug directly into the filtered faceplate, and if that is still the same, into the test socket. If its still the saem, then at least I know its not me..... and I will raise a ticket for the 21CN team to investigate. You comment reagrds alot of people having the issue and PlusNet doing nothing about it is interesting, I do hope they resolve this, as I will have to move back to ADSL if nothing improves.
Chris
05-04-2009 8:14 PM
05-04-2009 8:32 PM
Quote Comms seem not to be helping, and I have had no replys from Comms to this thread. Should I be raising a ticket now.....
yep i think they should have a couple of people pro actively looking for problems on adsl2+ instead of waiting for for people to kick a fuss up.
after all it is trial surely PN should be using this golden period before mass release to sort these sorts of problems posted about on the forum as these are going to come thick and fast when it's launched as a product.
Granted its a new BTw fault reporting system ect but the end user is only really bothered about how speed issues ect are sorted and PN is the face that they see in most cases and not BTw's
if it wasn't for a couple of members of staff that i know will a least try and get any problems i might see sorted when iam on the trial soon i wouldn't of let my line any where near the trial.
hope you get your adsl2+ line working soon penfold and i hope PN take note about pro actively looking for and sorting adsl2+ trial problems
sry for abit of a off topic post penfold but just needed to say it
05-04-2009 8:55 PM
Quote from: penfold Should I be raising a ticket now.....
Yes, I think there is a strong case for raising an upstream speed fault ticket. Don't forget to mention this 21CN Trial forum topic.
David
05-04-2009 8:58 PM
I agree with you, although we should be raising tickets, and I have done just this now, Comms seem to be conspicuous by their absence on this topic.. Also Spraxts comments are a little disturbing as well.
Quote You are not alone in experiencing this behaviour and it is something the Plusnet need to look into, but I've seen nothing that suggests they are doing so.
I am now in the ADSL Faceplate directly, and these are the current stats
BTW, the errors were definately at zero when rebooted, and this is a brand new Speedtouch 585V7, so I am not sure what a factory reset could do....
05-04-2009 8:59 PM
05-04-2009 11:02 PM
One thing that is apparent is that the DLM on 21CN is more responsive to changes in line conditions and target noise margins can reduce within a few days (example). So an increased target is far less of concern than on maxDSL. Fix any problem and the target should quickly go down.
David
06-04-2009 2:16 PM
Quote from: penfold Comms seem not to be helping
Apologies for not working a seven day week
When did your problems actually start? Was it on Friday? Realistically, we're unlikely to get any movement on this for you yet, due to the issues that are currently ongoing on London. However, as soon as these are resolved we can look at your upstream issues. There's also an outside chance that fixing Ilford may fix your connection, but we'll have to wait to see what happens.
