Upload and download speeds
Martin123453
Hey I'm not sure how else to get this sorted so iv come here, I want to increase my upload and download speed and I know only plusnet can do it my current upload speed is something around 0.34 is there any way of increasing this?
Fixes: 62
Re: Upload and download speeds
It rather depends
First question - if you put your phone number in http://usertools.plus.net/exchanges/ what does it say about WBC on 21CN
Second question please post the router stats as asked for here http://community.plus.net/forum/index.php/topic,96155.0.html
Fixes: 5
Your line was capped. I've asked BT to remove it, and you'll get the new speeds by tomorrow morning.
 Tony T
Martin123453
Quote from: plusnettony
im wondering if it could go any higher? as im trying to live streem aome video games but its lagging all the time
Line Attenuation (Up/Down) [dB]: 21.0 / 43.5
SN Margin (Up/Down) [dB]: 5.4 / 11.4
Bandwidth (Up/Down) [kbps/kbps]: 1,147 / 6,312
download speed 5.30 mbps
Upload 0.90 mbps
Fixes: 5
I'm afraid that's about the level to expect on this technology. Fibre does appear to be available for you, and that should drastically increase the up (and down)load speeds.
 Tony T
Martin123453
I'm currently on unlimited broadband paying around £18 a month, how much would I be looking at for the upgrade?
Fixes: 163
The standard costs for our fibre services are either £14.99 (plus line rental) or £19.99 (plus line rental). However our customer options team can quite often sort out a good deal for you if you get in touch on 0800 013 2632 or 0330 123 9197.
 Chris Parr
 Plusnet Staff
