Upload and download speed
tdingene
I joined Plusnet recently and my upload speed is much slower than it was when I was on Sky. I assume it is capped. How do I go about getting it uncapped?
Also my download speed is lower than I expected I was told I would get 14Mb (This may vary between 12.5Mb and 16Mb) but am only getting 10.6Mb. That isn't that awful and I can live with it but I was wondering if something is wrong.
These are my line stats:
Uptime: 3 days, 21:55:53
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 12.111
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,99
Output Power (Up/Down) [dBm]: 12,3 / 0,0
Line Attenuation (Up/Down) [dB]: 8,2 / 19,0
SN Margin (Up/Down) [dB]: 29,5 / 6,6
Loss of Link (Remote): -
Error Seconds (Local/Remote): 32.985 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 672.933
HEC Errors (Up/Down): 0 / 224.842
Thanks for your help.
danger11
Re: Upload and download speed
Maybe because of them errors? they look very very high
Fixes: 68
Hi there tdingene,
I've raised order 1-15033635456 for you to uncap the upstream of your connection tomorrow.
 Adam Walker
