Upload Times Out
nic2109
Upload Times Out
Hi. My daughter failed to submit a University assignment today as the upload kept timing out. As it was a PDF document of only 3.1 Mb this seems extreme (to say the least). The Uni is threatening to dock 10 marks for late submission we are trying to find out what the reason is.
The Uni IT Help Desk is blaming our ISP speeds but the Speed Tester shows an upload speed of 0.4mbps which ought to be adequate (d/l is 6.1 mbps).
We tried a good half-dozen time between Noon and 3pm. Can you please see if there is a reason for this issue?
Hope you can help.
Nick
1 REPLY
mliversidge
Re: Upload Times Out
Hi Nick,
I've fully checked your connection and can't find any issues to indicate there's a problem, further more as you're able to upload to the document to google docs that suggests the issue is on the universities servers.
I've posted the test results on your support question you've raised to us if you need to refer back to them.
Hope you get it sorted!
Regards,
Martin
