Upload Speeds.
Russell666
Upload Speeds.
Hi - I'm  currently getting upload speed of 0.39. Is this normal for basic adsl?
Fixes: 62
Re: Upload Speeds.
not normally
what connected speeds does your router show
Russell666
Re: Upload Speeds.
If I do an upload speed test via iDrive I get 0.31 mb/s. should I be looking elsewhere?
Fixes: 62
Re: Upload Speeds.
provide the information requested then we can advise
Plusnet Staff
Plusnet Staff
Fixes: 116
Re: Upload Speeds.
Hi there @Russell666 I've tested your line and I can see your upstream sync is at 1048 kbps so I'd expect you to receive a better upload speed than 0.39 Mb. Are you using a wired or wireless connection?
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
