Upload Speed
faite
Upload Speed
Is the upstream capped to 443kbps on the unlimited ADSL package?
Thanks.
Fixes: 46
Re: Upload Speed
It might be initially, but it will be uncapped on request. If you are moving from a existing package and have uncapped upstream changing product shouldn't cause upload speed to change (nor download speed for that matter).
David
faite
Re: Upload Speed
OK I'll put a request in.
Though I was told on the phone that the unlimited product is locked to 448 and cannot be changed. I hope this isn't true as ADSL2+ circuits can support 1.3+.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: Upload Speed
Hi faite,
I've responded to your request Smiley
Chris Pettitt
Cloud Environments Engineer
