Upload Speed
ScreaminWargasm
Upload Speed
Hi All,
Ive just read on the Plusnet website that upload speeds are capped at 448kb/s as standard but can be uncapped on request. Any of you know if this is right?
Seems strange that they'd do that to me!
My upload speed is around 300kb/s at the moment which is about 1mb lower than o2 provided me with.
Re: Upload Speed
Yes, they are normally capped at 448 up for ADSL2+ as most people aren't too worried about upload speeds and yes, they can be uncapped on request.  There's a remote risk that download speed or stability could be affected by the uncap but for most it is not an issue.
Call me 'w23'
ScreaminWargasm
Re: Upload Speed
Thanks for your advice. I'll request them to uncap it Wink
