Upload Speed
theberrys
Upload Speed
Is there anyway to increase my upload speed because I want to upload to youtube and if the files are more than a gigabyte then they take forever!
itsme
Re: Upload Speed
What upload speed are you looking for? On ADSL2+ it's up to 1.2mbps and I get 900kbps.
Fixes: 247
Re: Upload Speed
If you're on ADSL Max, you can get Max Premium for about £9 extra which will give you double upload speed
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
