Upload Speed
- Upload Speed
Upload Speed
20-06-2014 9:57 AM
how is everyone?
was wondering if anyone knew if i could increase my upload speed?
many thanks
Ade
Re: Upload Speed
20-06-2014 10:01 AM
Re: Upload Speed
20-06-2014 10:01 AM
thank you for your reply, do you know how i would find that out?
Re: Upload Speed
20-06-2014 10:03 AM
Re: Upload Speed
20-06-2014 10:05 AM
Uptime: 7 days, 17:17:09
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 443 / 21,751
Data Transferred (Sent/Received) [GB/GB]: 3.88 / 6.84
Output Power (Up/Down) [dBm]: 12.6 / 0.0
Line Attenuation (Up/Down) [dB]: 5.0 / 12.5
SN Margin (Up/Down) [dB]: 32.0 / 3.1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 3,949 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 35,171
HEC Errors (Up/Down): 0 / 11,121
Re: Upload Speed
20-06-2014 10:08 AM
I would assume that the staff on here will pick this up and do it for you
Re: Upload Speed
20-06-2014 10:16 AM
i'll sit and wait to see if someone picks this up
thank you
Re: Upload Speed
20-06-2014 10:19 AM
Re: Upload Speed
20-06-2014 10:24 AM
If you really want more speed Annex M may be available which would give 2.5Mb upstream with a slight reduction in downstream but this would cost £12 per month I believe (it is quoted as £10 for Business Broadband which I assume excludes VAT)
Re: Upload Speed
20-06-2014 11:24 AM
I've placed the order to uncap the upload and this is due to complete in the next 24 working hours. You should start to see an increase from Monday (at the latest) onwards. Let us know how it works out for you.
Re: Upload Speed
20-06-2014 11:29 AM
thank you, that's brilliant.
Jim mentioned the possibility about 2.5mbs upload depending on the annex m, is this something that can be looked into? i don't mind losing download speed
Re: Upload Speed
20-06-2014 11:50 AM
I've had a look at your line and on Annex M you'd be estimated an upload of 1.5Mbps.
I would suggest seeing how you get on with the uncapped upload and then making a decision about Annex M if you decide that the uncapped upload isn't working for you
