Upload Speed....
- Re: Upload Speed....
Upload Speed....
09-05-2013 2:24 PM
I've been with PlusNet since Saturday, and done a few Speed tests. I'm getting 12-13 Mb download, which is okay (17Mb was estimated) but Upload is only 0.2 - 0.34 Mb. That's worse than I was getting with TalkTalk. Will it go up after 10 days or can it be changed sooner.
Thanks....
Thanks....
Message 1 of 8
(1,021 Views)
7 REPLIES 7
09-05-2013 2:41 PM
Looks like you may need an upload uncap.
Either raise a ticket or one of the DC Team will pick up this thread.
Message 2 of 8
(554 Views)
09-05-2013 3:44 PM
.....raise a ticket.....
I don't know what that means.
Message 3 of 8
(554 Views)
09-05-2013 3:54 PM
To raise a fault ticket , you need to log in to the member centre on the main site then select 'help and support' (near the top), not sure if this link will work: https://portal.plus.net/wizard/?redirect=http%3A%2F%2Ffaults.plus.net%3Freturn_page%3D22224%26amp%3B...
Alternatively, telephone customer services.
Call me 'w23'
Message 4 of 8
(554 Views)
10-05-2013 10:02 AM
Hi mkay19,
Welocme to Plusnet and our community forums
I've placed a modify order to uncap your upload speed, this will complete for you on Monday(13th May).
I hope this helps.
I hope this helps.
Message 5 of 8
(554 Views)
10-05-2013 11:46 AM
Thankyou...I'll let you know.
Message 6 of 8
(554 Views)
14-05-2013 12:53 PM
Just to say, Upload speed now has gone up to 0.8. Download is slightly lower at 11.25
Thankyou.
Thankyou.
Message 7 of 8
(554 Views)
14-05-2013 1:39 PM
Message 8 of 8
(554 Views)
