Upload Speed
- Re: Upload Speed
Upload Speed
01-12-2008 4:26 PM
Date Download Speed Upload Speed
Today 16:15 6163 kbps (770kB/s) 308 kbps (38.5kB/s)
Today 16:08 6113 kbps (764kB/s) 310 kbps (38.8kB/s)
Today 01:04 6115 kbps (764kB/s) 309 kbps (38.6kB/s)
Saturday 09:19 6119 kbps (765kB/s) 310 kbps (38.8kB/s)
Friday 18:26 5728 kbps (716kB/s) 308 kbps (38.5kB/s)
Friday 11:34 6121 kbps (765kB/s) 310 kbps (38.8kB/s)
Thursday 10:00 6118 kbps (765kB/s) 305 kbps (38.1kB/s)
Wednesday 22:27 6135 kbps (767kB/s) 305 kbps (38.1kB/s)
Wednesday 09:05 6119 kbps (765kB/s) 306 kbps (38.3kB/s)
Nov 25, 11:58 6119 kbps (765kB/s) 308 kbps (38.5kB/s)
Nov 25, 06:23 6118 kbps (765kB/s) 309 kbps (38.6kB/s)
Nov 24, 23:57 6124 kbps (766kB/s) 309 kbps (38.6kB/s)
Last night I was uploading 25Meg to a website (not PN) and it seemed to take forever.
Peter
Re: Upload Speed
01-12-2008 4:28 PM
So I don't think you really have anything to worry about.
Re: Upload Speed
01-12-2008 4:31 PM
It's an 8 quid a month
Re: Upload Speed
01-12-2008 4:37 PM
@adiewoo
Double upload speed would be nice but I can't really justify an extra £8 a month for it for the times I do have big uploads.
I always said they'd got the planning wrong with Max - I'd have been much happier with 5Meg down and 1Meg up - I think they were a bit short sighted to assume that all people did was to browse web pages.
Peter
Re: Upload Speed
01-12-2008 4:39 PM
I'm sure Barry will correct me if I'm wrong, but I don't believe the frequencies on standard ADSL will allow upload speeds that high.
Re: Upload Speed
01-12-2008 5:02 PM
You're right, James - the frequency band for ADSL upstream is pretty narrow and it's also very difficult to squeeze any more bits into each tone. Max Premium adjusts the frequency spread used for upstream and downstream.
The basic frequency allocation for ADSL are:
* 0-4 kHz, voice.
* 4-25 kHz, unused "guard" band. (This essentially gives a buffer between the voice signal and the ADSL tones)
* 25-138 kHz, 25 upstream bins (7-31).
* 138-1107 kHz, 224 downstream bins (32-255).
Each bin can carry (up to) 15 bits.
I do tend to agree with pd - by sacrificing a little downstream bandwidth they could have improved the upstream. HOWEVER, this would have meant sacrificing the "most reliable" frequencies from the downstream, which certainly would have meant that some of the longer reach (61dB+ attenuation) lines may not have been able to receive an ADSL connection at all.
ADSL2+ does seem to allow some means of reallocating upstream/downstream "bins", but it does vary by DSLAM vendor so don't expect it to be easy!
B.
Re: Upload Speed
01-12-2008 5:10 PM
Quote from: Barry HOWEVER, this would have meant sacrificing the "most reliable" frequencies from the downstream, which certainly would have meant that some of the longer reach (61dB+ SNR) lines may not have been able to receive an ADSL connection at all.
I guess then that maybe they DID know what they were doing.
Peter
Re: Upload Speed
01-12-2008 5:12 PM
So, on a long-reach 61dB line, you could have been limited to 288K upstream, to give you perhaps 1M downstream. Those of you who live inside the exchange could have settled for a 5Meg downstream and 4Meg upstream if they had chosen.
Would have meant investing in more backhaul capacity upstream though..
B.
Re: Upload Speed
01-12-2008 5:22 PM
Quote from: pd I synch at 7616 with an IP profile of 6500.
What sync speed does your router report for upload?
Re: Upload Speed
01-12-2008 5:31 PM
Quote from: jelv
448kbps
Re: Upload Speed
01-12-2008 5:41 PM
Have you tweaked your MTU and RWIN settings? That might help.
Re: Upload Speed
01-12-2008 6:11 PM
I did tweak the MTU and RWIN some time ago but it didn't seem to make any difference. 365-375 is around the figure I would have expected.
Peter
Re: Upload Speed
01-12-2008 7:04 PM
Re: Upload Speed
01-12-2008 7:38 PM
Re: Upload Speed
07-12-2008 8:20 PM
