Upload Speed Very Low
lschlagel
I have just done a speednet test with the following results:
Download: 11.24 Mb/s
Upload: 1.09 Mb/s
Ping: 15ms
It seems my upload speed is extremely low.  As I hope to take a job doing online teaching, I have been told I need to increase this speed.
Please advise on how to do so.
Thanks for your help.
Laurie S.
lschlagel
Re: Upload Speed Very Low
Just to add I have a Plusnet supplied Thomson TG585 v7 router.
I was unable to get the router stats asked for as I was not able to log into the site using the information provided.
Cheers,
Laurie
Fixes: 62
That speed is just about the maximum you will get on ADSL2+ so unless fibre is available your only option is to move to a Business product and request Annex M for an extra £10 per month http://www.plus.net/support/broadband/speed_guide/upload_speeds.shtml
What speeds do they say you will need
Fixes: 24
Quote from: lschlagel
This strikes me as a bit fishy.  Surely nobody working from home will have faster upload speeds than 1 Mbps unless then have fibre or a special (non-domestic) version of the normal broadband service.  Your prospective employer must know this, if they know anything at all about what they are asking for..
I'd certainly try and have a look into what it is they are requiring you to do and 1MB upload would normally be sufficient generally. Fibre's not available for you at the moment and there in no date set either for it in your area.
