turn on suggestions
Upload Speed Issue
- Upload Speed Issue
Upload Speed Issue
Upload Speed Issue
02-02-2015 11:15 PM
Hi, I have been a customer for nearly a decade but am a first time poster.
I have long suffered a slow upload speed and done many plusnet tests including getting the BT engineer out (which helped the DL speed no end) but still a slow upload.
I am seeing many posts here of people getting there upload speed uncapped and am wondering if I could get the same.
Many thanks Welshvixen
Re: Upload Speed Issue
03-02-2015 10:32 AM
Hi welshvixen, welcome to the forums.
Are you able to post your routers connection stats for everyone to see. Also if you're able to let us know know what speeds your getting that would be helpful.
03-02-2015 12:30 PM
Hi thanks for the reply, here is some info!
Router NetGear DGN1000
Connection Speed: Down - 22014kbps / Up - 1190kbps
Line Attenuation: Down - 6.9DB / Up - 0.0DB
Noise Margin: Down - 2.3DB / UP 0.0DB
Current Line Speed: 19.4mb
Ookla test: Ping-28ms / DL-17.94mbps / UL-1:01mbps
03-02-2015 12:33 PM
your upload is uncapped and the upload speed test result confirms it
03-02-2015 12:40 PM
ADSL = Asymmetric digital subscriber line
Download= fast and upload = much slower
Ian
Ian
03-02-2015 2:45 PM
03-02-2015 6:24 PM
Thanks for the replies!
Although my results are showing an upload of 1mbps, I was actually surprised by it when typing, previously it had seemed to be capped at 0.30mbps.
I guess I'll have to wait for my neck of the woods to leave the stone ages before I can even make a video call in decent quality!
Thanks again for the replies, Welshvixen.
03-02-2015 10:16 PM
@ welshvixen - Assuming you're in Wales, have you looked here http://www.superfast-cymru.com/where-and-when about if fibre is coming to your area soon?
