Upload Speed Frustrated
rookey
Ok..
I have always manage to get 1.01 Upload speed but couple of weeks ago it dropped down to 0.38 and ever since it been like that.  Plus net has placed a order for it to be uncapped don't know why since i have always manage to get the max I can..
But I am still not able to get the speed I use to get it still at 0.38 and plus net have not done anything about it.  I have sent several message via twitter chat
I have always found this forum gets more help than any other method of contact...
So pls sort it
12 REPLIES 12
picbits
Re: Upload Speed Frustrated
Post your router stats up.
rookey
Uptime: 3 days, 15:21:15
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 445 / 20.723
Data Transferred (Sent/Received) [GB/MB]: 1,39 / 840,09
Output Power (Up/Down) [dBm]: 11,1 / 0,0
Line Attenuation (Up/Down) [dB]: 5,3 / 6,5
SN Margin (Up/Down) [dB]: 32,4 / 5,9
Loss of Framing (Local/Remote): 9 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 28 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 13 / 10
HEC Errors (Up/Down): 2 / 5
I have reset the router as was told to by the twitter guy 3 days ago
rookey
Any input guys,???
rookey
OMG just done a test 0.11 now
rookey
Right that's it. Am off bye bye plus net going ring Mr for MAC code.
JayG
Fixes: 6
Perhaps worth pointing out that there are no PlusNet staff manning this forum on Sundays...
rookey
Ok see what tmr brings. Been poor upload
rookey
Tested again this morning 0.22
AndyH
It would look like there's been an issue getting it uncapped.
jelv
Fixes: 10
Capped upload doesn't explain a speed of 0.11 - there's something else going on.
Can you confirm that you are seeing these speeds using a wired connection?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
MatthewWheeler
Fixes: 479
Sorry to hear about your issues.
I've reset the line which has took the upload cap off however even with the cap on the results shouldn't be that poor.
I'd recommend following Jelv's advice and trying a wired connection if you haven't done so already.
 Matthew Wheeler
rookey
Well well well
I've not been able to test by Hardwire till now and the line already be reset so my speed are now back to now it was both connection are the same... So something has happened on the line then as I am back to normal..
Shame I couldn't test it before line was reset to see if Hardwire made a different but I wouldn't of thoug so since wifi is now back to how it was it match the wire speed
