Upload Speed Drop
TeeGee
Upload Speed Drop
Just ran a speed test and discovered that my upload speed (ADSL+) has dropped from 1mbs to .5mbs.
Support do not answer the phone. Chat is unavailable. No indication that one can request restoration via the website. Seriously unhappy with CS.
Would like to find out why and how to restore the speed.
Any suggestions?
Fixes: 254
Re: Upload Speed Drop
Hi there.
Our tests aren't identifying any issues.
Can you run through the troubleshooting here and here for us and let us know how you get on?
Anoush
TeeGee
Thanks for reply. You can tell things were not working too well yesterday!
The BT speed tester was working fully a few minutes ago and returned readings of 9.0 down and 0.9 up which is what I would have expected, compared with the lower upload yesterday. I did however find it slow to connect to the Plusnet website  so there may have been some glitches at your end.
Thanks for checking. I will be more patient in future!
Fixes: 254
Your connection has been stable for the past 4 days
It looks like the test I completed about an hour ago caused the router to resync and now you're getting 1095kbps.
Running a line test is actually failing with a loop rectified fault which can cause intermittent problems so I'd recommend running through the troubleshooting above.
TeeGee
I have replaced the microfilter with a new one and connected it directly to the master socket. No other connections to phone line before or after. Just the phone and router.
Have run BT Speedtest - no noticeable change
Dial tone OK
Quiet line test 17070 totally silent.
Will leave it conected like this  until tomorrow so that you can if required do another test at your end.
Fixes: 254
Thanks for completing the checks.
Line tests are still identifying a potential loop fault. Can you plug your router into the test socket?
TeeGee
Router is in test socket via microfilter.
Fixes: 254
Line tests still detecting: FAULT - Loop (Rectified)
Could you disconnect everything from the test socket so I can retest with nothing connected?
Cheers
TeeGee
I will leave everything disconnected for ann hour. Can't get your reply until I reconnect!
Fixes: 254
Aye, I appreciate that.
I've tested your line [at 16:57] and we're no longer detecting an issue now.
The next step is to probably try a different router.
TeeGee
It is currently delivering 9.4 down and 0.9 up and I am quite happy with that.
The router is an oldish Netgear DGN 2200 but I also have a later N600 that I was given by a relative recently. Not sure if a change will have any further benefits as it streams BT Sport without any break ups - if it ain't broke , as they say.....
Many thanks for your help.
TG
Fixes: 254
...don’t fix it. Smiley
Happy to hear things are working well and your upstream is still back to normal.
Anoush
