Upload Cap Removal
pieandapint
Upload Cap Removal
Hi, is it possible to have the upload cap removed from my connection?
I occasionally upload photos to the cloud and find the 0.7Mbps cap a bit painful.
Thanks!
1 REPLY
Fixes: 20
Re: Upload Cap Removal
It's not capped if it's 684k, capped would be 448k or very slightly less.
I think the oldest type of ADSL2+ exchange equipment tends to give slightly worse upload speeds using ADSL2+ on long lines, and you might get a slightly better upload speed by switching your modem to ADSL2 (I am well aware that ADSL2 and ADSL2+ use exactly the same upstream frequencies, but it does affect the speed on the oldest ADSL2+ exchange equipment).
