Upload 145 and SNR of 13.9!
- Upload 145 and SNR of 13.9!
03-11-2016 10:01 AM
New to Plus Net from 25/10/16. Upload was in the 900's with SNR of 6, quite impressed. It's now been reduced to 1xx with a huge, unnecessary SNR to match. Why is this? and what can be done about it.
Re: Upload 145 and SNR of 13.9!
03-11-2016 10:12 AM
it sounds like you have a problem
Is the phone line quiet - dial 17070 option 2
When was the last resync and did it coincide with the phone ringing
A quick fix is tp resync the router which should get it back
03-11-2016 10:42 AM
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 36.8 | 60.5 |
SNR Margin: | 14.5 | 6.6 |
Errored Seconds: | 0 | 0 |
HEC Errors: | 0 | |
Cell Count: | 187692 | 2722014 |
Speed: | 145 | 3783 |
Initializations: | MIN:0 | MAX:22 | AVG: 6 (Times in an hour) |
22 disconnections in 1 hour is a very high number, the majority of these were between 2pm and 3pm on the 31st October.
Can you try a single disconnect/reconnect and see if the upload speed increases again for you.
Chris Parr Plusnet Staff |
03-11-2016 10:46 AM
Ah, that would be my grandson, who thought it made a nice click and the lights were pretty. It's now moved out of his way and shouldn't happen again! It's just reset and the upload is much better. Many Thanks
03-11-2016 11:08 AM
04-11-2016 11:28 AM
Router has just reset by itself and now given me an upstream of 69 and an SNR of 29.6
