Upgrading router firmware problem
- Upgrading router firmware problem
- « Previous
- 1
- 2
- Next »
Re: Upgrading router firmware problem
02-05-2014 1:40 PM
Please do not restart your router
02-05-2014 2:10 PM
02-05-2014 2:36 PM
02-05-2014 2:51 PM
02-05-2014 3:13 PM
Quote from: Chris @daniellewin89 - Is your router switched on?
02-05-2014 3:19 PM
02-05-2014 3:24 PM
02-05-2014 3:27 PM
02-05-2014 3:59 PM
05-05-2014 1:39 PM
It was 10.2.5.2 that I was trying to update to but I see it's been done now.
Thank you.
06-05-2014 10:23 PM
I have the TG582n FTTC with firmware 8.C.M.0.
Please push the update down to my router.
I am surprised that there isn't a utility in the router for this like my old Netgear router had.
07-05-2014 9:44 AM
We generally push firmware updates manually if there is a problem using this tool.
08-05-2014 9:19 PM
What is the difference between Plusnet - FTTC - TG582n (with USB port) - 10.2.5.2 and Plusnet - FTTC - TG582n (with USB port) - 10.2.5.2.FO ?
My problem is that since I upgraded to Fibre Essentials and started using the Plusnet - FTTC - TG582n my WD NAS could no longer access the internet and I therefore no longer had remote access to it. It worked fine with Plusnet BB using a Netgear router.
WD suggest assigning manual port forwarding to fix this but I cant see how to do this with the FTTC - TG582n.
Can I tell the router to allow internet access for the WD NAS?
- « Previous
- 1
- 2
- Next »
