In February 2024 we upgraded from a basic Plusnet ADSL service to a faster SoGEA one. (Lost our landline in the process!)
The line connects at 58 Mbps down, but only 5.1 Mbps up. Speedtest reports speeds of about 52 Mbps download, but only 4.7 Mbps for uploads. (Ping = 19mS). I've spoken to Plusnet support, who have tuned our line, but they say there is no guarantee on upload speeds. I was expecting something closer to 10 Mbps upload, and as I often upload large files this is an issue for me. At another location I use with Plusnet FTTC I usually see close to 10 Mbps upload speeds.
Are others getting 5 Mbps? Any advice? I haven't yet had another go at Plusnet.
Hi @WBJBlake!
Thanks for getting in touch, as pointed out by the adviser you spoke to upload speeds aren't guaranteed but taking a look at the speeds available in your area, you're hitting the correct upload speeds. They will differ from one property to another as it dependent on things like the length of the line and what speeds the local exchange can offer.
The guys on here might have some other tips for you as well
