Upgraded to Fibre
Fantomas101
Upgraded to Fibre
Hi Guys
Long time, very happy Plusnet customer, but first time poster on these forums.
I have been using standard broadband with a TP-Link TD-W8968 ADSL2+ modem router with no problems.
Yesterday, following a house move I had my new fibre connection installed.  Unfortunately the Plusnet router has not yet arrived.
I would therefore like to use my existing TP Link router which I have read should support fibre connections.
I have connected it the LAN 1 port of the Openreach modem to the WAN/LAN port on the TP Link router, but no joy.
I presume I will need to add in my connection details manaully on the TP link router ?  My other question is, do I need to change the mode of the TP link router  ?
Matthew
Re: Upgraded to Fibre
I'd expect as a minimum, you'll need to give it your logon details, and tell it to talk Ppoe from the LAN/Wan port, rather than using the ADSL port.
Fixes: 46
Matthew,
here you go http://www.tp-link.us/article/?faqid=480
Set the Connection Type to PPPoE and use the same username/password that you used for the ADSL setup.
Hope that helps
Fantomas101
Thanks guys, thats really helpful.  Will give it a try when I get home tonight Smiley
Fantomas101
Thanks guys
I've got everything connected now and can get on the internet  but I'm only getting around 7.5 Mbps download speeds.  Upload speed is around 18 Mbps.
This shouldnt have anything to do with not using the Technicolour router right ?  I read that I may locked on my old ADSL profile ?
I have restarted the equipment but no change.  I also know to expect some inconsistencies during the first 10 days, but I would expect faster speeds than this initially.
Matthew
Fixes: 62
It may sort itself out over night but if it doesn't I suggest phoning in and asking for the Plusnet profile shown here https://portal.plus.net/my.html?action=data_transfer_speed to be updated
Once done you may need to disconnect/connect the router - Not the modem
Fantomas101
Thanks Jim Smiley
I'll check it again tomorrow then.  I checked the link you provided and this is the output
Estimated line speed:
Current line speed:
7.8 Mb
Thanks again
Matthew
Fantomas101
Hi
I've tested the download speed again but still getting around 7.3 Mbps.  I've tried ringing the support line but faced with a 45 minutes wait.  Also, got a problem with my home phone so relying on mobile, which isnt great.
Can anyone from Plusnet check to see if my line is still using the old profile as none of my details seem to have changed on my account details.  Eg. still showing my old phone number.
Matthew
Fixes: 62
It is and I suspect it will need sorting out on Monday
Is the problem on the phone related to the fibre install - if it is I suggest raising a phone fault at https://faults.plus.net
xreyuk
Quote from: Fantomas101
Current line speed:
7.8 Mb
This current line speed value is your Plusnet profile, so if you're ever worried about speeds in the future, this is the first thing to check. It seems quite common for the Plusnet profile to stick to your old ADSL one for the first few days from what I've seen on this forum, as during the first two days, BT don't assign you a proper profile. This means the Plusnet profiling system has nothing to compare against and leaves you on the profile you were on.
VileReynard
Seasoned Pro
Fixes: 9
I'd be worried with a speed like that!
The engineer measured me to be 300m (via wire) from the local cabinet & I only get 58Mbps.
Plusnet Staff
Plusnet Staff
Fixes: 5
It looks as though the profile has automatically aligned, please let us know if you're still seeing poor speeds.
Chris Pettitt
Cloud Environments Engineer
