Upgraded to 21CN
- Upgraded to 21CN
Upgraded to 21CN
23-03-2012 12:37 PM
Re: Upgraded to 21CN
23-03-2012 12:54 PM
I have raised your profile to 14200 to allow for your new BT IP profile. This should take effect shortly.
I can see the disconnections you're on about, can you tell me if you're using any extension cables/sockets? Do you have a test socket you can plug into?
Jojo
23-03-2012 1:28 PM
The router is already connected directly into the main (and only) socket.
Mandy
23-03-2012 3:45 PM
23-03-2012 4:30 PM
I assume that there is a test socket behind the faceplate, but I've not actually checked before, I've not had need to before. I can try and get to it, but not until Monday as its hidden behind some furniture and I'm away for the weekend.
23-03-2012 5:12 PM
04-04-2012 5:24 PM
I'm still not able to get to the master test socket at the moment, but I should be able to do that early next week. My sister is getting married at the weekend so the house is a bit manic with people everywhere and I can't get the furniture out to reach the socket behind it.
04-04-2012 5:32 PM
04-04-2012 5:32 PM
sounds like a filter problem. Are you using filters on all phones in the house? If so the replace them just to rule that out. Let me know when you get a chance to put it in the test socket.
Jojo
04-04-2012 6:39 PM
Quote from: Mandoo The router is already connected directly into the main (and only) socket.
04-04-2012 6:43 PM
Quote from: Mandoo I assume that there is a test socket behind the faceplate, but I've not actually checked before, I've not had need to before. I can try and get to it, but not until Monday as its hidden behind some furniture and I'm away for the weekend.
Hence Jojo's comment.
13-04-2012 4:37 PM
Thinking of upgrading to Fibre now though so its not a huge concern at the moment.
25-04-2012 2:21 PM
I haven't noticed any problems since I changed the filter, but today I'm getting all sorts of issues. Numerous disconnections and slow speeds seem to be the main issues.
25-04-2012 4:10 PM
Looks like there's been a lot of disconnections very recently (early this afternoon in fact) but was alright until then... did something happen?
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13353665565643.png" />
25-04-2012 5:21 PM
I'll leave things as they are for now and see how we go, hopefully it was down to the weather or something.
