Upgraded to 21CN question
StormWarden
Not so long ago i recived an email from plusnet advising that as my exchange had been upgraded to 21CN my connection would be migraded in the following weeks.
On Monday i cheked the closed questions in the help assistant and found the following note:
The broadband service is now being transferred to the 21C Network.
The transfer will complete by midnight on 21/02/2012
This morning i rebooted my router and found that there had been no speed increase, speed tests indicated that my download speeds had remained the same.
My router is showing the following:
ADSL Type: G992_1_A
Downstream Data Rate (Kbps): 8064
Downstream Noise Margin: 7.5
Downstream Output Power: 7.9
Downstream Attenuation: 7.4
Upstream Data Rate (Kbps): 1056
Upstream Noise Margin: 12.0
Upstream Output Power: 10.6
Upstream Attenuation: 2.0
Would it be possable for someone to check my line and confirm that i have indeed been moved over to 21CN?
19 REPLIES 19
Fixes: 1,483
Re: Upgraded to 21CN question
Looking at the upload speed then you have been moved, it may take a couple of days for your profile to catch up for your download.
StormWarden
Just Checked https://portal.plus.net/my.html?action=data_transfer_speed
Estimated line speed:Not recorded (service activated before we introduced estimates).
Current line speed: 7.15 Mb
I am sitting on the dorstep of the exchange....almoat, surely i should see some speed increase?
Alos my router is showing that my line mode is G.992.1 whcih if the previous posts are correct, means that i am on ADSL.
spraxyt
Resting Legend
Fixes: 75
Does your router support ADSL2+? As you've just commented your stats currently show an ADSL1 connection but if Plusnet had provisioned migration on ADSL1 I'd have expected the upstream sync speed (Data Rate) to be 448kbps.
With your attenuation, on ADSL2+ your downstream sync speed should be near the maximum achievable.
David
StormWarden
Thanks for the quick reply,
I am currently usng a belkin N+ Modem-Router - Hardware: F5D8635-4v1.....should have given that on my 1st post  Embarrassed
According to Belkin the device is Compatible with ADSL, ADSL 2 & ADSL 2+
StormWarden
Have ran some further tests
http://www.speedtester.bt.com/
Download speedachieved during the test was - 6.94 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 7.11 Mbps
Upload speed achieved during the test was - 969Kbps
Additional Information:
Upstream Rate IP profile on your line is - 832 Kbps
Any help or advice would be greatly appreciated.
Regards
StormWarden
spraxyt
Resting Legend
Fixes: 75
That BT speedtester result includes an upload test so you are definitely on 21CN. However the stats you posted show an ADSL1 connection. It's possible that your router has been configured to connect with that protocol though the normal (default) setting is multimode where the router would try ADSL2+, ADSL2 then ADSL1 in turn.
Hopefully Plusnet will take a look at this in the morning.
David
x47c
I'd guess OP is on 21CN but on ADSL1
So the first message they got from Plusnet was technically correct in that they were being migrated to 21CN
The message said nothing about being upgraded to ADSL2+ !!
The upstream sync of 1051 seems like an upcapped one for an ADSL2+ connection - which I agree is odd for ADSL1
Most routers do not report downstream power figures on ADSL2+.  not sure whether this is a bug in the router software or the exchange software......but the stats provided by the OP DO show it.  Another reason to suggest they are on 21CN network but still on ADSL1.
StormWarden
I appologise I think i got myself confused    Crazy
This morning i rooted around my inbox an found the original notification and it did mention that I would still remain on my corrent speed.
"You will remain on the same 'up to 8Mbps' speeds that you have currently but are likely to see a better broadband performance".
What would need to be done so that i could get the higher speeds?
Regards
StormWarden
Fixes: 1,483
Ask nicely Smiley
StormWarden
Hi
Would you please upgade my line speed..... Grin
Refgards
StormWarden
jojopillo
Done, ticket/email confirmation sent Smiley
StormWarden
Thanks Jo,
Just cheked my router stats and it does show that my throughput has changed:
Type: G992_5_A
Data Rate - Downstream: 20215 - Upstream:888  Cheesy
Noise Margin - Downstream: 6.0  - Upstream: 15.8
Output Power - Downstream: 0.0 - Upstream: 10.9
Attenuation - Downstream: 9.3 - Upstream: 3.4
BT Speed Test
Download speedachieved during the test was - 6.83 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 17.83 Mbps
As I am in the training period this should change?
Regards
Oldjim
Resting Legend
Fixes: 63
Might be worth looking here with respect to your upload speed http://community.plus.net/forum/index.php/topic,102468.0.html and asking for interleaving to be turned off
spraxyt
Resting Legend
Fixes: 75
If you check Current line speed in the Member Centre you will probably find that still says 7.15Mbps. Plusnet might need to change account settings including increasing that to 17.8Mbps for you to see the increased speeds
David
