Upgraded to 21CN but no increase in download speed
RoBNor
I have been upgraded to ADSL2+ but my download speed is still around 6Mbps the same as it was before,my profile is 15.02Mbps (see attachment).My router is compatible with ADSL2+
houlton23
Re: Upgraded to 21CN but no increase in download speed
What does your 'Current Line Speed' say from here?
Fixes: 24
Given that you IP Profile is now around 15Mbps then it's probably Plusnet applying an unnecessary throttle to your speed because their systems aren't working properly.  Follow houlton23's link and if the number is any less than the IP Profile reported by the BT speedtest, phone Plusnet technical support and complain bitterly about it.
RoBNor
Fixed now download speed around 14.3 Mbps
Hi RoBNor,
Welcome to the Plusnet community.
I can see everything is running fine for you now.
Please let me know if anything changes.
Chris
RoBNor
Download speed is very erratic today,this afternoon anything from 4Mbps to 13 Mbps,this evening less than 1mbps.Sync speed 18mbps
I've checked your line and everything appears fine at the moment. I would keep an eye on it  and if it persists we can look into it further.
