Upgraded to 21CN - Peak time speeds very slow
- Upgraded to 21CN - Peak time speeds very slow
08-09-2010 8:31 PM
I've been on BB Premier Option 1 for years,and was upgraded to 21CN last week. Since then the speeds in the evening have been dreadful.
Just run a BT speed test (8.15pm):
Download speedachieved during the test was - 393 Kbps
For your connection, the acceptable range of speedsis 100-500 Kbps.
Additional Information:
Your DSL Connection Rate :18424 Kbps(DOWN-STREAM), 443 Kbps(UP-STREAM)
IP Profile for your line is - 350 Kbps
I ran the test this morning at 9am and my IP profile was 12500 and I managed a download speed of over 8000.
Router stats:
noise margin: 25.7dB upstream, 2.5dB downstream
Attenuation: 5.5dB upstream, 23dB downstream
Any suggestions?
Thanks - Kevin (username holohan)
Re: Upgraded to 21CN - Peak time speeds very slow
09-09-2010 11:47 AM
I've just checked your BT and PN profiles and they're both 16000, so I've absolutely no idea why you should see a profile of 350 on the speedtest. Are you sure you didn't inadvertently connect to someone else's wireless network?
Jojo
09-09-2010 12:38 PM
Nope - this was on a hard wired connection with the (desktop) PC (no wireless) running the test connected to the router.
The problem has been the same for the last 4 evenings that I've checked (upgade to ADSL2 happened on 2 Sept). Pings go out to over 400ms as well which isn't impressing the grumpy PS3 playing kids in the household.
The router remains switched on 24hrs/day. Until 1 Sept I'd had a rock solid connection.
I've now raised a ticket - 35092906.
Cheers - Kevin
09-09-2010 12:49 PM
I'm going to leave it with the faults guys as you have raised a ticket but I am going to check a few things myself for you, just in case I can see anything obvious. If I can, I will come back to you, otherwise we'll see what the faults guys make of it.
Jojo
09-09-2010 1:17 PM
I've just ran a line check and it all seems ok at the moment. We'll still leave the faults team to it but what I'll do is run a line check about 8 tonight and then 9 then 11and if I get any unusual results I can upload them onto the ticket for the faults guys to look at.
Jojo
09-09-2010 1:51 PM
Hope we can get to the bottom of this before my ears start bleeding through listening to the rest of the household complaining
Kevin
09-09-2010 2:34 PM
I will certainly try to help as much as I can. In the meantime I found something here that might help with your predicament.
Jojo
09-09-2010 10:12 PM
Just ran line test at 10PM, showing IP profile of 16000, just where it should be at the moment I'm afraid. Sorry I couldn't get one earlier, I had to go out.
Jojo
10-09-2010 7:47 AM
Last night was a better night. I ran a BT speed test at 8pm and the IP profile was 16000 and managed just over 6k download.
Best regards - Kevin
10-09-2010 9:27 AM
I think you should update your ticket to include the fact that you're only getting 6000 on a 16000 profile, that would be the most important thing to focus on at the moment, I think.
Jojo
10-09-2010 10:28 AM
Posted one recently my synch is about 15000, profile BT & PN 13000 but at 13:00 the BT got 3380 as down load and my speed 9500, (I have a problem on this machine with Avast hoggging download - XPSP3)
Also see attached, my speed did something funny Mt 585 I had to power down on the 7th - results of SamKnows monitoring
