Upgrade to fibre - slower than before!
- Re: Upgrade to fibre - slower than before!
16-04-2014 10:58 PM
I've just switched to FTTC broadband with a BT Openreach contractor turning up today (second attempt as BT simply cancelled the first appointment without a reason). The download speed is 3.5mb, when the estimated speed should be around 38mb. The upload is around 8mb which seems about right. Is this normal for new connections? I realise they take time to sync sometimes but it seems crazy that it's so slow.
cheers
cheers
Message 1 of 6
(1,096 Views)
5 REPLIES 5
16-04-2014 11:46 PM
Hi sdp,
Really sorry for the poor speeds you've had here. If you could reboot your router you should start to see an increase in speeds.
Message 2 of 6
(662 Views)
17-04-2014 1:04 PM
I had rebooted it last night (it having been installed mid-morning) and it was the same. I'll try it again this evening and let you know.
thanks
thanks
Message 3 of 6
(662 Views)
17-04-2014 1:53 PM
It shouldn't have been the same.
Can you ensure that you're connected with an Ethernet Cable so we can check your speeds without any interference.
Message 4 of 6
(662 Views)
18-04-2014 11:57 AM
I rebooted it again last night and it's come up at about 35mb - not quite as much as I was expecting but significantly better than before! I'd been using a wired connection for all of my tests, I guess it just took longer than I was expecting to increase the speeds.
thanks
Steve
thanks
Steve
Message 5 of 6
(662 Views)
18-04-2014 2:41 PM
Message 6 of 6
(662 Views)
