Upgrade to BBYW Pro
- Re: Upgrade to BBYW Pro
Upgrade to BBYW Pro
13-04-2008 10:21 AM
Any PN staff around, can you answer this one for me please.
I raised question 24723959 to get an upgrade from from PAYG to BBYW Pro, it was referred for manual intervention, and has now been closed but I see the account is still showing me on PAYG in the portal.
My question, is this correct, am I just being impatient, or has the agent closed it by mistake. If so can you get it re-opened to sort out the regrade.
Paul
Paul
Message 1 of 4
(960 Views)
3 REPLIES 3
Re: Upgrade to BBYW Pro - question closed
13-04-2008 10:48 AM
I would advise you to remove the "Question Closed" bit from your thread title or people wont read it
If you got to your first post and click Modify at the top, you can change it from there
Message 2 of 4
(345 Views)
13-04-2008 1:13 PM
IIRC orbrey works at the weekends, but yes, in principle, phoning would still be a good idea.
Message 3 of 4
(345 Views)
13-04-2008 2:37 PM
Apologies this was indeed closed by mistake and has been flagged for team leader attention. I've also changed the account type for you, please disconnect for 10 minutes and then reconnect as until this happens you will still be connected on the old account profile.
Message 4 of 4
(345 Views)
