Upgrade from copper to FTTC on TG582n
- Re: Upgrade from copper to FTTC on TG582n
09-10-2013 10:06 AM
I already have one of the not so great (http://gibbalog.blogspot.co.uk/2013/01/broadband-woes.html) TG582n routers as supplied by Plusnet for copper broadband. I want to make sure I've got a Plusnet supplied router in the house that is supported for FTTC - anybody know which router is currently being supplied if I order another one when moving to FTTC? Is it also a TG582n? I don't want to end up with 2 of them in the house as that seems a waste, particularly as I've no intention of using it unless I need support from Plusnet. Thanks!
Message 1 of 3
(2,156 Views)
2 REPLIES 2
09-10-2013 2:01 PM
We do supply the same router as on our ADSL product, although the fibre router does come with a USB port.
Message 2 of 3
(348 Views)
09-10-2013 2:55 PM
Chris,
Thanks for the reply. That's what I've been lead to believe and confirms I don't really need to get another one that'll just sit in the bottom of a drawer anyway.
Graham
Graham
Message 3 of 3
(348 Views)
