Upgrade Solutions for speed
- Upgrade Solutions for speed
07-10-2011 9:51 PM
I thought that there was a faster Plusnet package that was unlimited but had only 20gb of bandwidth, but is seems to have gone.
If I upgraded to a business package would I get faster broadband, they have a 50gb package which costs £5 more a month but I get "Upload speeds up to 1Mb", I am just wondering if there is a better contention on the business product?
The speed is variable with my current package from dire to bearable, the fact that it is faster after midnight suggests that the traffic management is part of the issue.
Has anyone here moved to business and got a speed improvement?
Re: Upgrade Solutions for speed
07-10-2011 10:36 PM
However you will need to give some more information if you want a sensible recommendation.
What package are you on at present
Router stats - noise margin, speed and attenuation
Is your exchange 21CN enabled
What are you using to measure the speeds - speed tests or downloading files
Have you looked here to check the degree of traffic shaping on the various packages http://usergroup.plus.net/prodcomp1.php
08-10-2011 10:58 AM
Plusnets cut-off speed for moving to 21CN ADSL2+ is 4Mbs. If your current speeds are below 4Mbs then 21CN ADSL2+ is not an option.
09-10-2011 10:45 AM
"I am stuck on an exchange that is not going to get updated anytime soon, so what are my options."
So no 21cn, more like 17cn!
I am on Extra
I usually use speed test but I checked the BT wholesale, at your suggestion in this thread:
http://community.plus.net/forum/index.php/topic,98387.0.html
Recent tests
In the last thread the BT test showed my connection rate at
Your DSL Connection Rate :7616 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 6500 Kbps
and my router mirrored this at the time with
Up Speed 448000
Down Speed 7616000
SNR Margin 12.0
Loop Att.17.0
But now the router is worse
Up Speed 448000
Down Speed 6816000
SNR Margin 9.5
Loop Att.17.0
I noticed the SNR margin is lower, but I do not know the significance of this or how to fix it
I did contact Plusnet about your suggestion to ask for interleaving to be switched off, but they came back with a message saying it would make it more unreliable so I was going to come back here and check your thoughts.
I did another BT test today and it says
Download speedachieved during the test was - 4437 Kbps
Additional Information:
Your DSL Connection Rate :6816 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5000 Kbps
So it appears I have been downgraded to 5mb and my connection rate is 6816.
So I am in a worse place than I was when I last posted.
Any help or suggestions would be appreciated.
I would rather stay with Plusnet but I need more speed, if paying for business with VAT on top would get me there I would do it. There is no hope of 21cn or ADSL2 or any upgrades in the exchange.
09-10-2011 10:56 AM
Quote from: Peter Also remember the quoted figures for business packages don't include VAT so bare that in mind when comparing with residential packages.
That is interesting, a friend was on Talk Talk and had a dire line performance (0.5mb) Talk Talk blamed the wiring between the house and cabinet (some sort of shared copper) they said BT Wholesale would charge them £1000 to fix it but BT would do it free if they were a BT Customer.
The BT tests suggested that they would get 3mb if they moved up to 24mb, not a lot but 600% better than what they had.
They put up with it for a couple of years and then decided to move to Plusnet, they called Talk Talk to give them one more chance and they upgraded the line to Fibre and I gather changed wiring as part of that upgrade, they now have between 8gb and 12gb.
What you are saying is that if they had gone with Plusnet, because their ADSL speed was below 3gb they would not be upgraded?
09-10-2011 11:10 AM
Up Speed 448000
Down Speed 6752000
SNR Margin 10.0
Loop Att. 17.0
09-10-2011 3:11 PM
Quote from: Peter
That's news to me. I've just been moved to ADSL2+ and my speed was 750k! Now slightly better at 940k but hoping for more as I'm still in the training period.
Kevin
11-10-2011 11:43 PM
12-10-2011 5:30 PM
Your line could probably go quicker. Are you using any extension cables/sockets? Can you plug into the test socket?
Jojo
12-10-2011 5:41 PM
It was just a few weeks ago I was on here complaining because it was rated at 7.6 and you had it at 6.5, now it is rated at 6.5 and you are providing 5.
I think it might have been because I was away.
In the post http://community.plus.net...ex.php/topic,98387.0.html
Jim suggested asking for interleaving to be switched off but your techs told me it would make things worse, so i did not go ahead.
Are you able to get me re-synched or rated so I can at least get back to where I was?
12-10-2011 6:12 PM
Before doing anything else you need to find out why your speed has dropped and fixing it - easier said than done
12-10-2011 6:22 PM
http://community.plus.net/forum/index.php/topic,99105.0.html
12-10-2011 6:34 PM
Quote Up Speed 448000
Down Speed 7616000
SNR Margin 12.0
Loop Att.17.0
Up Speed 448000
Down Speed 6816000
SNR Margin 9.5
Loop Att.17.0
12-10-2011 10:50 PM
13-10-2011 8:08 AM
Jojo
