Upgrade Firmware
- Upgrade Firmware
Upgrade Firmware
21-02-2011 3:53 PM
Re: Upgrade Firmware
21-02-2011 3:55 PM
21-02-2011 4:40 PM
As Jim suspects, if you are using wireless to do this it won't work, you have to do it wired.
Jojo
21-02-2011 4:49 PM
For OP's benefit you lose your wireless connection during update hence need for ethernet connection. I've done a few Thomson upgrades and these have never failed using cable but first one I ever tried failed as I didn't know not to try wirelessly.
21-02-2011 7:40 PM
21-02-2011 7:42 PM
21-02-2011 7:56 PM
22-02-2011 8:57 AM
22-02-2011 10:00 AM
22-02-2011 10:46 AM
If you're using a computer that normally connects by wireless then you probably need to disable this while connecting to the router by ethernet cable.
22-02-2011 11:54 AM
22-02-2011 2:43 PM
Sorry didn't get back to you sooner, we're 2 staff down on Digital Care today so having to spread ourselves around a bit more than usual.
Jojo
22-02-2011 5:31 PM
23-02-2011 10:06 AM
The upgrade is to fix issues with wireless connectivity. If you are not having issues then you don't need to upgrade it.
Jojo
