Updating to ADSL2+ when my exchange is enabled...
nickw7coc
Hi all,
My account is Plusnet Unlimited, when my exchange is enabled ADSL2+ at the end of March will I automatically get updated to work with it ?
I've seen a few posts on the forum commenting about the attenuation of the line and thing I may have a problem there...?
The following is from my SAFECOM GART2-4115
Modem Status
Connection Status   Connected
Us Rate (Kbps)           448
Ds Rate (Kbps)           8128
US Margin                   28
DS Margin                   2
Trained Modulation   GDMT
LOS Errors                   0
DS Line Attenuation   24
US Line Attenuation   11
Peak Cell Rate           1056 cells per sec
CRC Rx Fast           0
CRC Tx Fast           0
CRC Rx Interleaved   4647
CRC Tx Interleaved   146
Path Mode                   Interleaved
Nick - learning again  Shocked  Roll eyes  Undecided
Fixes: 10
Re: Updating to ADSL2+ when my exchange is enabled...
You can't have ADSL2+ on Unlimited.
If you switch to Pro or Premium you will get it. With your attenuation you could expect to get around 18000 Kbps.
Incidentally, have you looked at having interleaving turned off - your stats suggest that would be well worth a try.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Addnan
How do you tell if interleave is turned on, on a DG834G?
Fixes: 10
Look at the telnet pages for the detailed stats. The easiest way to do that is using RouterStats
