Update to my router
FIXEDTopic Options
- Update to my router
16-02-2023 10:15 AM
Hi there, I've been with Plusnet many years and am still on the original router 1(?) which we received when we first signed up. This is how struggling with the number of devices that we are running.
Looking on the MSE site it seems we should have been offered a new router on each renewal of contact and certainly when we upgraded to fibre we should have been offered a Plusnet hub 2. It's it possible to request one now and how would I do that.
Fixed! Go to the fix.
Message 1 of 3
(886 Views)
2 REPLIES 2
Accepted fix
16-02-2023 10:23 AM
@Stephenclutton You are no longer automatically allocated a new Hub on renewal, although you can request one if needed. The Hub1 is an ADSL/Fibre capable device, although now rather old.
When is your contract due for renewal? You may get one if you call up and request, even now - for the P&P of £6.99
Re: Update to my router
17-02-2023 7:38 AM
Hi John
Thanks for the help and advice. Called support and I've got a shiny new Hub 2 on the way
Cheers
Steve
Cheers
Steve
