Up load speed lower than expected - where should I be checking.
My upload speed has dropped to around 0.18 Mbps
My current router (TG585 v7) stats are:-
Uptime: 0 days, 19:51:45
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 224 / 2,912
Output Power (Up/Down) [dBm]: 11.0 / 18.0
Line Attenuation (Up/Down) [dB]: 27.5 / 50.0
SN Margin (Up/Down) [dB]: 6.0 / 15.0
Loss of Framing (Local/Remote): 11 / 0
Loss of Signal (Local/Remote): 1 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 11 / 0
FEC Errors (Up/Down): 0 / 3,057
CRC Errors (Up/Down): 0 / 33
HEC Errors (Up/Down): 0 / 32
If I rest the router the speed go back to:-
Uptime: 0 days, 0:00:42
Bandwidth (Up/Down) [kbps/kbps]: 448 / 3,200
Output Power (Up/Down) [dBm]: 12.0 / 17.5
Line Attenuation (Up/Down) [dB]: 27.0 / 49.0
SN Margin (Up/Down) [dB]: 23.0 / 12.0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
The problem returns after a while.
SN Margin would usually be (Up/Down) [dB]: 23.0 / 12.0 I am currently getting SN Margin (Up/Down) [dB]: 6.0 / 15.0
So is this a IP profile issue or something I need to look at?
Dan.
Fixes: 62
Re: Up load speed lower than expected - where should I be checking.
Something you need to look at.
Does the low upstream resync happen when the phone rings
Just been using the phone I have a faint very intermittent crackling on the line, which is not good news.
Time to go through the motions of proving its not my wiring that is causing the issue (again)  Cry
The line has not been the same since copper thieves took a hacksaw to it, we now have an extra connection or two on the line to the exchange.
Dan.
If you are hearing crackling on the line then it is going to be something that we do need to look into. I'd certainly do the internal checks first and if it's still apparent then I'd raise a fault at http://faults.plus.net
