Up Stream noise doubled
HaresEar
Do my connection need a kick. PPOA disconnected and now my upstream has been halved and the noise margin doubled.
Can some one take a look please?
Fixes: 62
Re: Up Stream noise doubled
Can you try a resync and see if it fixes it as it could well have been a resync when there was a burst of upload noise
Plusnet Staff
Plusnet Staff
Fixes: 159
I'm taking a look now.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
I can see that you're syncing at 440 on the upstream and the SNR has indeed increased quite a lot. I've just submitted an SNR reset which should take effect within the next couple of hours and reset your line.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
Can you try a disconnect, then reboot the router, then reconnect when you're available and see if the upload speed changes.
 Chris Parr
 Plusnet Staff
Fixes: 62
Why would the upload speed change with a PPP drop
Plusnet Staff
Plusnet Staff
Fixes: 159
It won't, error on my part. I've corrected my previous post.
 Chris Parr
 Plusnet Staff
HaresEar
Chris I have Tried disconnecting and rebooting but upload snr is still 25db.  Line seems Ok.
HaresEar
Speed results
Plusnet Staff
Plusnet Staff
Fixes: 159
I'm going to suggest you open a fault on this as I've checked the line and it's still showing as uncapped upload but something obviously isn't right. Can you go through https://faults.plus.net and I'll point someone in this direction.
 Chris Parr
 Plusnet Staff
Fixes: 150
Hi there.
I've tried to poke some things in order to get your upload speed back to normal.
Unfortunately it won't complete until Monday but keep a eye on your speeds on Monday and fingers crossed they should increase.
 Matthew Wheeler
HaresEar
Ok I won't raise a fault just yet then. Just changed from BT HUb4 back to pulsate and it is just the same.
I'll see how things go.  Stats from router
DSL Connection
Link Information
Uptime: 0 days, 0:03:29
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 440 / 14,770
Data Transferred (Sent/Received) [MB/MB]: 1.04 / 19.62
Output Power (Up/Down) [dBm]: 12.3 / 0.0
Line Attenuation (Up/Down) [dB]: 16.2 / 30.0
SN Margin (Up/Down) [dB]: 28.8 / 6.1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 140
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 8
HaresEar
No change my end Chris. I'll raise a fault tomorrow.
Plusnet Staff
Plusnet Staff
Fixes: 159
Hmm thanks, I was hoping that would do the trick.
 Chris Parr
 Plusnet Staff
